Court Record wont work as intended.
PhoenixCorrection
Post by PhoenixCorrection »
For some reason, it wont let me add elements to the Court Record... It will just skip the frame.
Update: It adds the element now, but still skips the frame
drvonkitty
Re: Court Record wont work as intended.
Post by drvonkitty »
Do you have the wait timer set to anything? Or is it a blank frame with just the "Reveal elements in the court record" action set? If the latter, the frame definitely shouldn't be skipped. However, make sure you don't have the wait timer set to a low number (like "1"). That would cause the frame to be skipped.
PhoenixCorrection
No its not, it just has the action Reveal elements from the court record.
Update: Ok, for some reason it works fine now and I haven't been able to replicate the glitch since... So I guess problem solved? :ron:
o
