Zoomed out sprites
Zoomed out sprites
How do I make the small zoomed out sprites appear in the correct place? I have them, but they want to go to the incorrect spot. Edit: Alright, I'm using Gimp, but I need the sprites in the gallery area to move, seeing as it's the start of the trial.
- SuperAj3
- Spoken languages: English, 日本語(少しだけ)
Re: Zoomed out sprites
Hi,
You'll need to edit the sprites in advance before uploading. The size of a DS screen (that AAO uses) is 256 pixels wide by 192 pixels tall.
If you make an image of that size with the mini sprites all placed in position, and then upload that image, you can load it in as a pop up over the courtroom overview.
I don't understand why "need the sprites in the gallery area to move" is important. Can't you just make everything except the "zoomed out sprites" transparent and overlay them on the Agitated background?
Gimp doesn't want to do that.
It doesn't want to go to the correct place the first time. I tried to use snipping tool then upload to Photobucket. Still goes to the incorrect place. I'm pretty sure it's scaled properly.SuperAj3 wrote: ↑Thu Nov 26, 2020 1:10 am Hi,
by
- SuperAj3
Could you please share the images you're using? I'll try to edit them for you to show you what I mean.dawsongfg wrote: ↑Fri Nov 27, 2020 7:07 amIt doesn't want to go to the correct place the first time. I tried to use snipping tool then upload to Photobucket. Still goes to the incorrect place. I'm pretty sure it's scaled properly.SuperAj3 wrote: ↑Thu Nov 26, 2020 1:10 am Hi,
by
SuperAj3 wrote: ↑Fri Nov 27, 2020 7:27 amCould you please share the images you're using? I'll try to edit them for you to show you what I mean.dawsongfg wrote: ↑Fri Nov 27, 2020 7:07 amIt doesn't want to go to the correct place the first time. I tried to use snipping tool then upload to Photobucket. Still goes to the incorrect place. I'm pretty sure it's scaled properly.SuperAj3 wrote: ↑Thu Nov 26, 2020 1:10 am Hi,
by
Here are the images.
It is definitely possible to do this in GIMP. I do this on a semi-regular basis. I can go into details, but I think SuperAj has this under control.
- SuperAj3
See how I've laid them out in one image? You can do this and then add it as a popup in the editor.
At this point, making it transparent won't help photobucket because it doesn't use the format, so I'd need to use snipping tool, which doesn't exactly work properly. Edit: Nevermind, figured it out.
Got it. Thanks!
- SuperAj3
Use imgur instead of photobucket. That has unlimited bandwidth and doesn't add watermarks.
