Request Topic
- Chocoflair
- Spoken languages: English, Japanese
Re: Request Topic
May I have every AAI Old Dick Gumshoe (DS Quality) sprites? Including his Shocked/Surprised sprites? Thank you very much!
- SuperAj3
- Spoken languages: English, 日本語(少しだけ)
Re: Request Topic
AA Wiki has them: https://aceattorney.fandom.com/wiki/Dic ... .28AAI.29_Chocoflair wrote: ↑Sun Jan 10, 2021 8:50 am May I have every AAI Old Dick Gumshoe (DS Quality) sprites? Including his Shocked/Surprised sprites? Thank you very much!
- Chocoflair
Re: Request Topic
Forgot to add, not from AA Fandom or court-records.net, is it available? I don't want broken ones, sorry. Thanks anyway.
- SuperAj3
Re: Request Topic
I'm confused. Those aren't broken. At least on my end all gifs on that site appear and play just fine. You could always download a sprite sheet from CR or spriters-resource and put them together manually using EZGif?Chocoflair wrote: ↑Sun Jan 10, 2021 11:43 am Forgot to add, not from AA Fandom or court-records.net, is it available? I don't want broken ones, sorry. Thanks anyway.
- Chocoflair
Re: Request Topic
May I have the perceive from AJ? Here's an example:
Thanks if you may!
Thanks if you may!
- SuperAj3
Re: Request Topic
Hi! Perceive isn't natively supported in AAO and is quite tricky to implement. MercurialSK and drvonkitty custom coded it into their case, A Turnabout Called Justice, but I'm not sure if you can use that code without their permission.Chocoflair wrote: ↑Mon Jan 11, 2021 3:22 pm May I have the perceive from AJ? Here's an example:
Thanks if you may!
EDIT: Assets are on court-records: http://www.court-records.net/rips/GS4/m ... 4basic.png
- Chocoflair
Re: Request Topic
I needed them for different purposes not AAO.
- Chocoflair
Re: Request Topic
I needed them for different purposes not AAO. I needed the GIF ones or ripped ones though, Thanks!
- SuperAj3
Re: Request Topic
Hi, I've edited my above post with the ripped ones. You'll just need to animate them using a gif program or gif maker and they should be good to go!Chocoflair wrote: ↑Mon Jan 11, 2021 4:01 pm I needed them for different purposes not AAO. I needed the GIF ones or ripped ones though, Thanks!
- Chocoflair
Re: Request Topic
Sorry to break it to you, but it's not edited yet. The court records net link still shows.
- SuperAj3
Re: Request Topic
The link contains the 4 frames of animation used in that perceive segment. You'll just need to animate it yourself. I can attempt it for you if you'd like?Chocoflair wrote: ↑Mon Jan 11, 2021 4:39 pm Sorry to break it to you, but it's not edited yet. The court records net link still shows.
If ever you're struggling to find something, giving it your best go at animating it yourself is probably the fastest way. Most of what you've asked for is official assets either already made/animated and there's only so much I can do from my end before it falls on you to put the pieces together.
EDIT: Here you go: I've positioned it so the "perceive" button can appear up top and textbox below.
You can do these in like, a minute, if you have the frames needed and something like paint.net on your computer. Just clean away the background, cut out each part and save them as individual images, then upload them to https://ezgif.com/maker and save your gif.
- Chocoflair
Re: Request Topic
Oh, i see. Thank you very much though!
- Chocoflair
Re: Request Topic
AAI Old Franziska (HD) if it exists, please. I need every sprites.
- Chocoflair
Re: Request Topic
AAI Old Franziska (HD) if it exists, please. I need every sprites of her from AAI.
- SuperAj3
Re: Request Topic
https://www.forums.court-records.net/vi ... 12&t=32795 Post 4 by Initiate has a back up link if the main one didn't work.Chocoflair wrote: ↑Tue Jan 12, 2021 3:56 am AAI Old Franziska (HD) if it exists, please. I need every sprites of her from AAI.
Also FYI, You only need to post once, no need to ask twice.
