Tricks to a Cross-Examination
Re: Tricks to a Cross-Examination
@Enthalpy -
Thanks, I think I should be able to manage it.
@Revolution -
The exact reason why I want to do it is too long to explain fully. But the simple version is "the judge is a monster who talks in 'rawr', the prosecutor's a robot, there's no defense, the trial is overall more screwed up in concept than Ace Attorney canon, and the witness is just that terrible". Basically there's a sorta-good reason for it, just don't have time to explain completely why.
@Revolution -
- E.D.Revolution
Nobody has called me that in two years...
Anyway, if you're going to do that, keep your evidence and statements to a minimum so you can code it much more easily.
Hey, you linked to my tutorial. I'm flattered.E.D.Revolution wrote:Possible, but nigh impractical. I can see its uses for false contradictions, but, beyond that, why would you want to do that?
I can see this happening for very vague CEs (and even then, kept to fewer than 5 statements including reveal), but it becomes a pain for the author and it will become much more of a pain for the player. You also run into the problem of combinations of statements and evidence as shown here. In short, not recommended.
- E.D.Revolution
Added two basic CE techniques: Rotating Statements and Press to Obtain Evidence.
Are there any other basic CE forms that I should add here?
- E.D.Revolution
Reformatted the guide to reflect the skills needed to pull off most of the contradictions. Most of the sections have a few notes about writing on them, like how to use X effectively.
- Tulipau
- Spoken languages: Español, English, русский. Learning PT and FR.
Thank you, very interesting tutorial
I'm having some problems with Press to Obtain Evidence, I can't get the code to work properly. I'm probably doing something stupid, but here are my questions:
Should X (Preuve/Profil) be in quotes? single or double quotes? What about Y (the evidence ID)? Should preuve/profil have any capitals? Does this still work in V6? Do I need to end the codeblock with a semicolon or something?
Sorry for my stupidity, I've been trying to get this cross-examination working for a month now and I'm running out of ideas.
- E.D.Revolution
f:evidence_is_revealed('X',Y)
Single quotes only on X because it's a string, aka "word", not a value. I don't think it matters how you case the word "preuve" or "profil" as long as it's spelled correctly. Play it safe, though, and keep it all lowercase. Y doesn't need quotes. No Semicolon. Just a colon after "f" because "f:" means "function:"
In other words...
f:evidence_is_revealed('preuve',1)
if the first evidence is the attorney badge means
check that "function: evidence number 1 is revealed" is true.
This works in v6.
I can change the info here, but not in the other guide because that's under judgement for BAoL Tutorial Comp.
In other words...
This works in v6.
E.D I can't find the "Enter Cross-Examination" in the actions tab. Has it changed? If it did, can you make an updated version?
E.D.Revolution wrote:Note: This guide will soon be outdated. If you are using v5, keep on reading. If you are using v6, go here.
