[Bug][E,P] Hiding Back Button Crashes Player
All discussions regarding the AAOv6 Beta, be it bug reports or suggestions, should be posted in this section.
Selecting for the back button to be hidden results in any of the three "ask for player's input" actions hangs the player.
On a related note, this button cannot even be selected unless at least one "load from runtime action" is selected.
Re: [Bug][E,P] Hiding Back Button Crashes Player
This parameter is not supposed to be visible on normal frames in the editor (unless you switch to advance mode, which shows everything), and for a good reason : it's contextual.
What do you think it would return to if you just tick the box on a normal frame ?
It's only supposed to be used when in a psyche locks conversation.
...Now I feel silly for even reporting the second one as a "bug." That makes perfect sense.
The first one remains, however.
