I've got a scenario I would like to incorporate into a case, but as it stands now, the only way to do this (as far as I can tell) would be immensely impractical. Specifically, I would like to have text shift upwards as you would see in a chatroom or IRC or whatever. It's easiest to demonstrate this with an example:
Pretend that this charming image is the
background I plan to use in my case,
and that this block of text is the
object. I want to be able to move this
block of text up line-by-line in order to
replicate an IRC (online chat) sort of
thing.
As it stands now, if I wanted to repeatedly shift the text upwards I would need to make hundreds of objects of the block of text in different locations and reveal/hide them as the text "scrolls". If, on the other hand, there was a function that allowed me to set new coordinates for an object, I would only need one object.
Honestly, this seems to be a pretty extreme example of re-using objects and I don't see this being a highly-useful change for most people, but considering how much time and tedious work it would save me, I thought I'd ask anyway.
[Suggestion] Moving Object in a Location
Re: [Suggestion] Moving Object in a Location
I'm fond of the idea. I'd need to do some more checking to see if it's feasible, but it should be possible?
Why not, I guess it could make sense.
Somehow I'm not too fond of the idea - it reminds me of the "modify a piece of evidence" thing that was requested a while ago and which was a really bad idea, But here it does make sense so why not.
An action to update the object's position should be fairly simple to implement, except for one thing : the action execution should cause a re-render of the top screen's place layer, so that if this location is currently rendered on screen it is updated accordingly. This might be a little bit tricky to do in a clean way.
- Ferdielance
This is an excellent feature for certain engines! I brute-forced this with direct trial data editing for Endless Nine, but that's not efficient. Hmm.
Endless Nine was the first thing that occurred to me when I saw this suggestion... So yes, I'm fairly interested in this one.
