Servidor Minecraft
¡Discute cualquier videojuego aquí, sea Ace Attorney o cualquier otro!
samuko
Re: Servidor Minecraft
Post by samuko »
lukas-heredia wrote:
diegomr24 wrote:he conseguido el minecraft, un dia de estos me conecto con vosotros
Ojalá, hijo, ojalá
¿Qué versión usa el servidor?
Es que cuando quiero entrar me dice error.
samukomini wrote:Lukas, lo he hecho y aun así sigue mal, esto es lo que me pone:
 Bad video card drivers!
Minecraft was unable to start because it failed to find an accelerated OpenGL mode.
This can usually be fixed by updating the video card drivers.
--- BEGIN ERROR REPORT 7fe0271 --------
Generated 3/02/13 21:19
-- System Details --
Details:
	Minecraft Version: 1.4.7
	Operating System: Windows XP (x86) version 5.1
	Java Version: 1.7.0_13, Oracle Corporation
	Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
	Memory: 417921840 bytes (398 MB) / 518979584 bytes (494 MB) up to 1037959168 bytes (989 MB)
	JVM Flags: 2 total; -Xms512m -Xmx1024m
	AABB Pool Size: 0 (0 bytes; 0 MB) allocated, 0 (0 bytes; 0 MB) used
	Suspicious classes: No suspicious classes found.
	IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
	LWJGL: 2.4.2
	OpenGL: ~~ERROR~~ NullPointerException: null
	Is Modded: Probably not. Jar signature remains and client brand is untouched.
	Type: Client (map_client.txt)
	Texture Pack: Default
	Profiler Position: N/A (disabled)
	Vec3 Pool Size: ~~ERROR~~ NullPointerException: null[failed to get system properties (java.lang.NullPointerException)]
org.lwjgl.LWJGLException: Pixel format not accelerated
	at org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(Native Method)
	at org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(WindowsPeerInfo.java:52)
	at org.lwjgl.opengl.WindowsDisplay.createWindow(WindowsDisplay.java:185)
	at org.lwjgl.opengl.Display.createWindow(Display.java:311)
	at org.lwjgl.opengl.Display.create(Display.java:856)
	at org.lwjgl.opengl.Display.create(Display.java:784)
	at org.lwjgl.opengl.Display.create(Display.java:765)
	at net.minecraft.client.Minecraft.a(SourceFile:232)
	at asq.a(SourceFile:56)
	at net.minecraft.client.Minecraft.run(SourceFile:515)
	at java.lang.Thread.run(Unknown Source)
--- END ERROR REPORT b1ee1502 ----------
¿Usas la tarjeta ATI o tarjeta NVIDIA?
Yo, desde luego que uso envidia, pero me callo, que no quiero dar envidia, ajajaja(ni gracia :P)
Bueno, pongamonos serios:
Descargar los drivers de aquí(es el más usado).
Si lo descargas y no funciona, dime tu Sistema Operativo y te los paso.
EDIT: Creo que tu SO es Windows 8, así que mira este video.
Si el problema persiste, díselo a tu hermano, o te grabo un video.
¿Has probado también descargar DirectX?
Noo sé tanto de infºrmatica... ¿podrías, eh, explicarme lo que quieres decir...? :P
lukas-heredia
Post by lukas-heredia »
Venga, vale, te haré un vídeo :P
Toma mi tutorial.
samuko
Post by samuko »
¡Muchas gracias señor Heredia!
Pero cuando abro la carpeta me salen muchas cosas :gumshoe:
lukas-heredia
samukomini wrote:¡Muchas gracias señor Heredia!
¿Cómo que muchas cosas?
¿Qué carpeta?
Y no me llames señor, tengo 1 año menos que tu hermano.
Que no, que no, llámame como quieras :P
samuko
Post by samuko »
lukas-heredia wrote:¿Cómo que muchas cosas?
¿Qué carpeta?
Carpetas de:
-FAQ
-ICON
-QUICK_INSTAL_GUIDE
-README
-TOOL
-UTILICE_DUAL_MAC_GUIDE
-WIN8
U otras cosas como:
-_setup.dll
-AutoInst
-data1
-data1.hrd
-data2
-Eng_LangID
-Inst_Ctrl
-InstOpt
-ISSetup.dll
-layout.bin
-setup
-setup (con un bloc de notas con esto:)
CompanyURL=http://www.realtek.com
ErrorReportURL=http://www.installshield.com/isetup/ProErrorCentral.asp?ErrorCode=%d : 0x%x&ErrorInfo=%s
MediaFormat=1
LogMode=1
Skin=setup.isn
Resource=_Setup.dll
SmallProgress=N
SplashTime=
CheckMD5=Y
CmdLine=
ShowPasswordDialog=N
EngineVersion=15.0.0.591
EngineBinding=1
[Languages]
Default=0x0009
count=33
key0=0x0009
key1=0x002d
key2=0x0002
key3=0x0003
key4=0x0804
key5=0x0404
key6=0x001a
key7=0x0005
key8=0x0006
key9=0x0013
key10=0x000b
key11=0x0c0c
key12=0x040c
key13=0x0007
key14=0x0008
key15=0x000e
key16=0x0021
key17=0x0010
key18=0x0011
key19=0x0012
key20=0x0014
key21=0x0015
key22=0x0416
key23=0x0816
key24=0x0018
key25=0x0019
key26=0x0c1a
key27=0x001b
key28=0x0024
key29=0x000a
key30=0x001d
key31=0x001e
key32=0x001f
RequireExactLangMatch=0x0804,0x0404
-setup.inx
-setup.ins
-setup.iss
-setupctrl
Etcétera.
Un lío
lukas-heredia
¿Pero dónde está esa carpeta?
Lo único que debes hacer es descargar el plug-in
instalarlo y analizar como yo lo hice.
PD: Ésto es lo que me pasa en Minecraft:
Problema en vídeo.
samuko
Post by samuko »
_Y exactamente, ¿cómo se llama el plugin?
lukas-heredia
Te subo otro vídeo y me ahorro explicaciones :P
Lo subo en dropbox por simple comodidad y rapidez
Descárgalo aquí.
diegomr24
Post by diegomr24 »
cada dia mas vago ¿eh?
lukas-heredia
diegomr24 wrote:cada dia mas vago ¿eh?
La próxima grabo mi voz y respondo por no escribir XD
diegomr24
Post by diegomr24 »
Jajajaja, por cierto... te has dado cuenta de que somos las dos únicas personas que al parecer, siguen vivas?
Crivtox
Post by Crivtox »
Chris Aikawa Ace Attorney - Mis sprites
(Spam power!)
Spoiler : ¡Aviso de epilepsia! :
sfcpfc
Post by sfcpfc »
Entre que me masacran a examenes y mi ordenador está kaputt...
diegomr24
Post by diegomr24 »
Bueno, vale, hay más gente viva, pero a veces no lo demuestran
Llevamos dos días comentando solo Lukas y yo.
lukas-heredia
¡SFCPFC!
¿Nueva imagen de perfil XD?
Me suena de algo eso...de algún opening de alguna serie...
¿Cómo se llama?
