I deleted all cache and cookies and it still happens.
Has this happened to anyone, and do you know how to fix it? thanks.
Only about 15% of the images load, in the photo; evidence, places, and playtest are shown.
https://github.com/mousyttr/ConvP2/raw/main/Masked3.pngCode: Select all
https://mousyttr.github.io/(whatever the path to the file is)/Masked3.pngCode: Select all
https://raw.githubusercontent.com/mousyttr/ConvP2/main/Masked3.pngTimeAxis wrote: ↑Sat Mar 25, 2023 3:33 am It seems like github changes its files' URLs internally every once in a while. The current URL for that image looks like this:
Theoretically, you could just switch all your URLs to use that format instead, to fix it. But this would likely be a temporary fix if they ever change it again. Using the Github Pages method, or hosting on imgur, will ensure your files always have the same URL. (Until the eventual imgur apocalypse some day, anyway, like what happened with photobucket)Code: Select all
That's only if you don't have an account, I believe. The ones stored in your account are stored forever*. I've got some from 7 years ago still sitting around in mine.
This is no surprise, but nothing that I'm aware of change in AAO.
