If you don't know how to access the console, right click on some blank spot on the trial page, click "Inspect", change the tab of the window to "Console" and paste all the code in and press Enter.
What it should look like:
// Text copier 3 with colors added.
function colormark(text) {return text.replace(/#\/instant/g, "#/colour").split(/\[#\/colour:.*?\]|\[\/#]/s).join("%c")} // "s" makes dots match newline
function findcolors(text) {return text.replace(/#\/instant/g, "#/colour").match(/\[#\/colour:.*?\].*?\[\/#]/s) ? text.replace(/#\/instant/g, "#/colour").replace(/#\/instant/g, "#/colour").match(/\[#\/colour:.*?\].*?\[\/#]/gs).map(i => 'color: ' + i.match(/colour:(.*?)\]/s)[1]) : []}
var lookup = trial_data.profiles.map(x => x!=0? x.short_name : "")
var merged_with_prev = false
var showindex = true
var rv = []; var rvcolors = []
for (let i = 1; i < trial_data.frames.length; i++) {
let x = trial_data.frames[i]; let speaker = ""; let newline = `\n`; let colors = [];
colors = colors.concat(findcolors(x.text_content))
let text = colormark(x.text_content) ? colormark(x.text_content).replace(/\[#.*?\]/gi, "").replace(/\[#\]/g, "") : ""
let green_transition = (x.text_colour == "#00F61C" || x.text_colour == "lime") && ((x.speaker_id == -3 && x.speaker_voice == -3) || x.place != 0)
if (!green_transition) {text = text.replace(/\n/g, " ")}
if (text == "") {continue}
function insert_between (array, element) {return array.reduce((r, a) => r.concat(a, element), [element])}
if (x.text_colour == "red") {text = `%c${text}`; colors = insert_between(colors, "color: red")}
else if (green_transition) {text = `%c${text}`; colors = insert_between(colors, 'color: #00F61C; background: black; display: block')}
else if (x.text_colour != "white") {text = `%c${text}`; colors = insert_between(colors, `color: ${x.text_colour}`)}
else if (x.text_colour == "white" && colormark(x.text_content)) {colors = insert_between(colors, `color: ${x.text_colour}`).slice(1)} // if there's any color modifiers but base is white
if (x.speaker_id > 0 && !merged_with_prev) {
speaker = `%c${x.speaker_name}%c: `
if (x.speaker_name == "") {
speaker = `%c${lookup[x.speaker_id]}%c: `
colors = [`color: white; background: darkblue; font-weight: bold; border-radius: 2px; padding-left: 3px; padding-right: 1px; padding-top: 1px; padding-bottom: 1px`, `color: white`].concat(colors)
if (merged_with_prev) {
rv[rv.length-1] += text; rvcolors[rvcolors.length-1] = rvcolors[rvcolors.length-1].concat(colors)
if (x.merged_to_next) {merged_with_prev = true} else {
console.log(rv[rv.length-1], ...rvcolors[rvcolors.length-1])
} // Set for next frame
continue
if (x.merged_to_next) {merged_with_prev = true} else {merged_with_prev = false} // Set for next frame
text = text.replace(/ +/g, " ")
rv.push(`${showindex? `${i} `:""}${speaker}${text}`)
rvcolors.push(colors)
if (!x.merged_to_next) {
} /* code written by main_gi to read AAO trials */
function colormark(e){return e.replace(/#\/instant/g,"#/colour").split(/\[#\/colour:.*?\]|\[\/#]/s).join("%c")}function findcolors(e){return e.replace(/#\/instant/g,"#/colour").match(/\[#\/colour:.*?\].*?\[\/#]/s)?e.replace(/#\/instant/g,"#/colour").replace(/#\/instant/g,"#/colour").match(/\[#\/colour:.*?\].*?\[\/#]/gs).map(e=>"color: "+e.match(/colour:(.*?)\]/s)[1]):[]}var lookup=trial_data.profiles.map(e=>0!=e?e.short_name:""),merged_with_prev=!1,showindex=!0,rv=[],rvcolors=[];for(let e=1;e<trial_data.frames.length;e++){let r=trial_data.frames[e],o="",t=[];t=t.concat(findcolors(r.text_content));let c=colormark(r.text_content)?colormark(r.text_content).replace(/\[#.*?\]/gi,"").replace(/\[#\]/g,""):"",l=("#00F61C"==r.text_colour||"lime"==r.text_colour)&&(-3==r.speaker_id&&-3==r.speaker_voice||0!=r.place);function insert_between(e,r){return e.reduce((e,o)=>e.concat(o,r),[r])}l||(c=c.replace(/\n/g," ")),""!=c&&("red"==r.text_colour?(c=`%c${c}`,t=insert_between(t,"color: red")):l?(c=`%c${c}`,t=insert_between(t,"color: #00F61C; background: black; display: block")):"white"!=r.text_colour?(c=`%c${c}`,t=insert_between(t,`color: ${r.text_colour}`)):"white"==r.text_colour&&colormark(r.text_content)&&(t=insert_between(t,`color: ${r.text_colour}`).slice(1)),r.speaker_id>0&&!merged_with_prev&&(o=`%c${r.speaker_name}%c: `,""==r.speaker_name&&(o=`%c${lookup[r.speaker_id]}%c: `),t=["color: white; background: darkblue; font-weight: bold; border-radius: 2px; padding-left: 3px; padding-right: 1px; padding-top: 1px; padding-bottom: 1px","color: white"].concat(t)),merged_with_prev?(rv[rv.length-1]+=c,rvcolors[rvcolors.length-1]=rvcolors[rvcolors.length-1].concat(t),r.merged_to_next?merged_with_prev=!0:(merged_with_prev=!1,console.log(rv[rv.length-1],...rvcolors[rvcolors.length-1]))):(merged_with_prev=!!r.merged_to_next,c=c.replace(/ +/g," "),rv.push(`${showindex?`${e} `:""}${o}${c}`),rvcolors.push(t),r.merged_to_next||console.log(rv[rv.length-1],...rvcolors[rvcolors.length-1])))}
