[T][CE] A Turnabout Called Justice ★
- drvonkitty
Re: [T][CE] A Turnabout Called Justice ☆ (Finally released)
No, unfortunately not. It is technically playable, but some SVG files won't show properly in Chrome. This means the perceive text doesn't appear, and you have to brute force it to find the tic. It also means the fades don't work properly, but that's not an issue with gameplay. I guess I could add a bypass to the perceive to make it playable on Chrome.
Huh, I thought Chrome would have full SVG support by 2021. Oh well, Firefox it is!
Sorry to drag this out, but I'm getting "image not loaded" warnings on part one. Can you give this a check to make sure the images are still fine? I know that one of Trucy's built-in sprites isn't in AAO, so that's part of the red, but I doubt all of it.
- drvonkitty
It's a casualty of the dropboxpocalpyse, unfortunately. The one set of things I wasn't able to recover was the mood matrix overload SVGs. Most of them are unused (I just never got around to removing them), but it does mean the mood matrix overload part doesn't have a visible blinking emotion. It's just a visual issue, though, as the section is fully playable. I can see if I can contact SK about recovering the files, and I'll go ahead and remove the unused ones now.
Edit: Oh, I just saw you said Part 1. I just went through and removed the only missing file I could find. Does it look correct now?
Edit edit: I think all the loading errors should be fixed now, let me know if not. Looks like it's just the tiny sliver caused by the Trucy sprite error.
Work has been hectic, so I haven't had time for this. Apologies. This week should be the end of it, so I can play over the weekend.
- drvonkitty
Update: I can actually get to the QA, and I finished the investigation this evening.
I'm not sure if this is a bug or intended.
- drvonkitty
Yep, that’s intentional.
This QA is going to be another weird one.
Spoiler : Part 1 of ??? :
- drvonkitty
Okay, that's all useful context for me. I'll say that after the current case I'm working on (in between other AAO administration/development projects), the case I want to write touches on one of the themes you mentioned, but I don't want to spoil it this early in the development cycle.
Here's what I'm envisioning for the first part of the logic patchup.
Let me know if this is the scale of things you could work with.
Before I continue on to the next part, I do need some plot points clarified:
Spoiler : Part 2 of ??? :
- drvonkitty
All of this looks manageable. Hopefully I'll have some time to start going through and patching things up. Responses to everything in green.
Okay, yes, all good character choices. That'll tweak the next set of recommendations. There'll probably be one more recommendation post tomorrow, but I think it's worth making sure you still agree with me this far.
- drvonkitty
