[P] "Crossfade to same playback position" doesn't work with looping tracks
TimeAxis
Post by TimeAxis »
User Agent String: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/113.0
Link: https://aaonline.fr/player.php?trial_id=145227
What happened?: When selecting "Crossfade to same playback position" on a track that loops, instead of crossfading to the same playback position, it crossfades to the loop point instead.
What did you expect to happen?: It should crossfade to the same playback position.
Can you reproduce the problem?: Yes, as seen in the linked example trial.
What did you do before the problem showed up?: Created a non-looping track and crossfaded it to the same playback position, to show how it should normally work, then created looping versions of the tracks and tried it with those.
Other
