[E] Music/SFX selection not updated when hovering over another frame element.
DeathByAutoscroll
Post by DeathByAutoscroll »
User Agent String: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:124.0) Gecko/20100101 Firefox/124.0
Link: Link to gif showcasing issue
Spoiler : Same gif link embedded :
What happened?: When selecting a sound or music track through the mini-window, the frame isn't updated with the selection until the user clicks. This can lead to scenarios where a user selects a sound effect, hovers over another element of the frame UI, and the sound effect is treated as if it was not set at all. This is especially annoying with larger cases with a lot of custom audio where selecting the track you want forces your mouse other another frame element making it almost impossible to properly set a selected sound.
What did you expect to happen?: The sound selected from the dropdown menu to update as soon as it was selected, meaning if the window closes the selection is saved.
Can you reproduce the problem?: Yes.
  1. Hover over either the mini music editor or sound effects window
  2. Select a sound from the dropdown
  3. Hover over either the main frame window, or the music editor/SFX window (whichever is not being used) without clicking outside the open mini window first.
What did you do before the problem showed up?: Struggle.
Things I have made or have directly helped make, in chronological order:
