Text commands in the text section.
Ooookay, I just need to know more about the pause shake and flash effect....I push the pause button, and a [#] pops out. That doesn't make it pause...it just shows up in the text. How to use these commands? XOrochiX Much obliged.
Re: Text commands in the text section.
Yes this is in the wrong section. =D Wasn't paying attention.
- Prinny_Baal
Uh, I'm pretty sure that's going to be compiled as a wait. Or something akin to that. When you actually run the trial it shouldn't have any problem. Is it not working correctly or something?
"I can do this dood!"
Wrong section. XD
There's a Bug Reports section, this is usually reserved for major site-wide announcements.
Umm, about your question, I have no idea, as I don't know how to work the trial maker at all.
Are you erasing the spaces that come with the [#]? Maybe? Just a guess, I'm probably totally off. >_>
Don't worry, I moved it for you. :]
And I don't see what should be the problem, it usually pauses for me when the [#] is there... I guess we have to wait for Forcemaster, huh?
Brb.
Lol. The world is coming to an end! XD
There may be a problem when the pause tag is inserted inside colour tags, because text between colour tags is displayed instantly (and thus other tags are not taken into account. But when you use them in a normal text (with a general colour and no colour tags inside), it should work. That's the only problem that should appear, as far as I know.
