It's such a simple thing but I haven't gotten it to work.
What I'm looking for is to define a variable number between 1 and 5, COMPLETELY random. So each time the variable is defined it picks out a random number between 1 and 5.
One small question; Which coding language do Variables take in? (JS, Python, etc?)
Probably something everyone already knows (I don't, I'm sorry xD)
(TIMEAXIS TO THE RESCUE, WHERES MY BOY)
Thank you. <3
Define a Variable to RANDOMLY select a number?
Live life as you enjoy it, pal!-
I guess not...
I guess not...
Re: Define a Variable to RANDOMLY select a number?
Go into advanced mode and mark the variable value as a runtime expression. Then set the variable value to .
f:random_int(1, 5)
Oh, that's way easier than I thought it would be, thank you Enthalpy my friend!
(So PHP it is)
(So PHP it is)
Enthalpy wrote: ↑Fri Sep 15, 2023 3:55 pm Go into advanced mode and mark the variable value as a runtime expression. Then set the variable value to.Code: Select all
f:random_int(1, 5)
I guess not...
I guess not...
For your other question, it’s all technically within javascript, not PHP, but the expression system is sort of a custom scripting language designed by Unas, so you can’t necessarily rely on any knowledge of existing languages.
This thread, particularly the “Henke’s explanation of the expression engine” part, lists all the functions you can use. I recommend bookmarking it or something cause it’s a really useful thread.
Gaiden Episodes
Champion of Turnabouts ★
HALLOWEEN HERO
Other
I can heartily endorse that tutorial.TimeAxis wrote: ↑Fri Sep 15, 2023 8:53 pm For your other question, it’s all technically within javascript, not PHP, but the expression system is sort of a custom scripting language designed by Unas, so you can’t necessarily rely on any knowledge of existing languages.
And yes, the expression system is a custom scripting language. Unas thought that letting users execute arbitrary code might be a security problem.
I SERIOUSLY never knew that! Ty for the link! Unas is one heck of a cool guy-
Oh my goodness. Thanks you two, that explains alot! <3
Enthalpy wrote: ↑Sat Sep 16, 2023 4:10 amI can heartily endorse that tutorial.TimeAxis wrote: ↑Fri Sep 15, 2023 8:53 pm For your other question, it’s all technically within javascript, not PHP, but the expression system is sort of a custom scripting language designed by Unas, so you can’t necessarily rely on any knowledge of existing languages.
I guess not...
I guess not...
